TwinTurbo.NET: Nissan 300ZX forum - Yes, sometimes brownish fluid can signify oil is leaking
Subject Yes, sometimes brownish fluid can signify oil is leaking
Posted by doug8867 on November 10, 2005 at 7:43 AM
  This message has been viewed 48 times.
In Reply To I thought that meant something about a head gasket posted by Shawn300zTT GT28R MD on November 10, 2005 at 01:49 AM
Message into the coolant, however if you saw this stuff and the thickness of the first few gallons removed you'd know right away it wasn't oil.
Plus the coolant didn't turn brown until after I added the stop leak, so I kind of put 2 and 2 together as to the cause. Oil also doesn't "dry" and stick to the inside of the hoses and other places since oil and water don't mix well, but tends to "float in the liquid so you can see a difference.
